PDFpen is well integrated with EF. I use PDFpen Pro, but I find it tends to crash when doing OCR on documents over about 40 pages. Hence I often end up using Adobe Acrobat. Is there a way to write an equivalent script for scanning a document using Acrobat (instead of PDFpen) after it’s in EF?
Does PDFpen Pro crash for other people when they try to OCR large documents, or is it just me?
On a side note, I also use PDFkey to unlock documents that prevent copying. If I discover them before I put them into EF, it’s easy to do. But often I find such a document after it’s already imported. That requires me to do a little “dance:” open PDFkey, drag the document from EF onto PDFkey, drag the converted file from the desktop to where I want it in EF, add back any tags and notes. Finally I trash the original document in EF, and the converted file on the desktop. If there were a way to “unlock in place” that would be a big help.
