Is it possible to show the mode the Airpods Pro are currently in:
- Noise Cancelling
- Off
- Transparency
If not, will it be possible to incorporate this feature?
Where would you like to see that displayed?
The app could inject an extra status icon into the menu bar and then change it based on the mode the Airpods are in.
Or you can change the airpods icon proper to add some indication of the current mode.
I was just wondering if it is possible at all, because I can’t tell right away if noise cancelling On or Off, or if transparent mode on or I just did not fit the airpods properly.
Thanks for the suggestion. It’s not possible with the current version, but I will see if I can add some sort of indicator. I think that will be technically possible.
In Mac Os 10.15, this is shown when clicking on the loudspeaker menuelet and then choosing the airpods. But indicated in the status icon would be nicer. Suggestion: A Circle around the symbol for noise cancelling, a perforated circle for transparency.
Great app, thanks!
