auto open
Is there a way to make Eagle Finder open a certain library automatically on startup?
I only have one library, so it would be nice not having to go manually and select it from the drop down menu each time I open the program.
Thanks
kim
Not at present, but that feature will be added in the next version. You could. of course, make an alias of your library (or put it in the Dock) and open EagleFiler by opening the library instead of double-clicking the application icon.
Perfect Solution
Perfect solution!
Thank you!!
Yes, EagleFiler 1.1 adds the “Remember open libraries between launches” and Startup Items](http://c-command.com/eaglefiler/manual-ah/remember-open-libraries) features.
