Hello,
Is there a way to “Auto” Select a file from the list in the folder tree, without clicking always Select ?
Karsten
Hello,
Karsten
If you double-click it, EagleFiler will select it in a new window. You could also use Command-Option-R, the keyboard shortcut for the Select button.
But why not always select with single click ?
Because that would be inconsistent, and there are other reasons for selecting a file in the records list besides wanting to select it in the source list.
Ok, maybe put Select in the menu for right mouse button.
Yes, I think that would be useful.
This was added in EagleFiler 1.3.
