This is probably a big project, but I was wondering if we could have some automator actions. I know applescript and all, but sometimes making a workflow in automator is easier.
Could you give some examples of actions that you’d like to see?
Some actions
- Putting an incoming object into a specified folder in the library
- If you had built-in ocr, ocr incoming pdf
- Applying selected tags to an incoming item
I know that you could do this with applescript, but it would be nice to take output from another application directly rather than use the to import folder, and then apply the above things. These are just some ideas
I’d like to add some Automator actions, but I also want to point out that you can use EagleFiler from Automator via the “Run AppleScript” action. For example, to import into a particular folder and apply tags:
on run {_input, _parameters}
tell application "EagleFiler"
tell library document "EagleFilerTest.eflibrary"
set _folder to library record "MyFolder" of root folder
set _tags to {"unread", "from_automator"}
import files _input container _folder tag names _tags
end tell
end tell
end run
To OCR and then import:
repeat with _file in _input
my ocr(_file)
import files {_file}
end tell
end repeat
end tell
end run
on ocr(_file)
tell application "PDFpen"
open _file as alias
tell document 1
ocr
repeat while performing ocr
delay 1
end repeat
delay 1
close with saving
end tell
end tell
end ocr
thanks for those scripts. I’ve had a brain storm. What do I need to change on those scripts to do a folder action. Especially the ocr to eaglefiler. The reason is my scanner does a lot but I can’t seem to make it do anything but scan to a folder. The driver and app is not applescriptable. Replace the on run to the folder action handler for handling files?
I understand if you don’t want to get into an AppleScript tutorial here.
I think that would be sufficient. I’ve added such a handler here.
that’s what I thought would be needed. You didn’t have to do that, but thanks anyway. More of a C, C++, Java programming teacher here. Just Getting used to Applescript.
