batch command for errors window
My errors window is showing a rather long list of missing files. I follow the instructions, " … click “Reveal in Library” and then press Delete to remove the record from the library." ; but the list is long and I’m wondering if there is not a quicker way to empty it. I want to remove all these records from the library at once.
morton
You don’t have to do it through the Errors window. If you can find the files in the main window, you can delete them from there. You could probably use a smart folder to search for all the missing files by date. (They’ll all have the same “default” date, since EagleFiler can’t find the files in order to load the real dates.)
Thank you. Problem solved.
