Hi - I have Text-Wrangler 5.5 and I wonder if this is compatible with BBAutoComplete? I don’t seem to have the Script directories in the right places. Though TW5 does have a Scripts directory strangely I can’s see it in Finder. MacOS 10.13.6
Apologies for putting this in EagleFiler - wasn’t sure where else to put it.
ta
ABB
It should work with all versions of TextWrangler, though with the free version of BBEdit now offering more than TextWrangler did you may prefer to just use that.
There should be a command in TextWrangler’s Scripts menu to open the proper folder.
I moved it to the General forum.
Thanks Michael,
Having found the right folder - I didn’t realise Finder hid some folders out of the box, though the BBAutoComplete manual does mention this! - it now works fine. Thanks for such a prompt reply.
ta
ABB
