Best way to export 600 messages for Law Firm
HI, Using EagleFiler have created a database of the pertinent Inbox and Sent files. Doesn’t appear to be a batch export to PDF. If I purchased a copy of EagleFiler for the law firm, how should I copy and move the library file to the Firm?
There is no batch PDF export feature. The EagleFiler library uses standard file formats, so you should be able to import the mailboxes into any mail app to read them on a Mac or PC that doesn’t have EagleFiler.
