What I want to accomplish is to block domains via blocklist and have spamsieve automatically delete them, so they do not go to junk or trash. I want to make sure that they are being blocked.
I have created entries in the spamsieve window blocklist. See attached.
I have created a blocklist rule in Mail. Note that the “delete” seems to supersede the other actions no matter what I try. This is not working everything I set up on the blocklist is still going to Junk or Trash. See attached.
I have the other spamsieve options checked. See attached.
What do I need to have set up in the blocklist and or spamsieve to accomplish the request above? I believe I may have too many options enabled, or incorrectly configured.
It looks like you made other changes than what I suggested. The Rescue Good Messages SpamSieve rule should be active and at the top. The second rule should be SpamSieve [Score], and it needs to be active, too. Each rule should only have one action.
If you have Mail set to delete spam messages before you see them, you should periodically review SpamSieve’s Log window to see whether there are any messages that you need to train as good.
