I have been jusing Airmail with Spam Sieve (3.1) for some time now. Mostly, it does a good job of collecting spam to the Spam folder. With Spam mail that does get through, the log says SS hasn’t seen it, which i surmise means something in Airmail has moved it to the inbox after SS has scanned it?
Anyway, my real question is that Airmail has some powerful Rules that can be configured. I started using these because, while SS does filter the spam to the Spam folder, I get tired of going thru dozens and dozens of spam from the same senders. For instance, Renewal by Anderson, Orangetheory Fitness, and JG Wentworth to name three. They usually will use different “from” addresses, but there’s almost always something in the from:, subject:, or to: that I can use. So I set up a rule to move them to the trash, and play a sound. For instance, see attached screenshot of one I use for “political” spammers. (Hope you can see this, couldn’t find “attach” so used “upload”)
My question is: Am I messing up SS with these rules? As they’re usually working with the Spam folder, not the Inbox, I wouldn’t thinks so, but…?
Thanks, Chris
