Bug in Outlook - Filter Mailboxes script
I think I found a bug in 2016-06-06 version of “Outlook - Filter Mailboxes” script.
on mailboxesToFilter()
    set _result to {}
    set _names to my mailboxNamesToFilter()
    repeat with _name in _names
        tell application "Microsoft Outlook"
            considering case
                set _matches to (every mail folder whose name is _name)
            end considering
        end tell
    **end repeat
    set _result to _result & _matches**
    return _result
end mailboxesToFilter
should be changed this way
    set _result to {}
            considering case
            end considering
        end tell
        **set _result to _result & _matches
    end repeat**
    return _result
Thanks for the report. I’ll fix this in the next version.
This is now fixed.
