running the new version:
select multiple records, call up tag inspector
applying tags to multiple records - works fine if you use the mouse.
using the space bar doesn’t apply tags to selected records, but deletes other tags from the same records
Thanks for the report. As a workaround until I fix this, it should work if you type the first letter or two of the tag’s name before pressing the spacebar.
I believe this is fixed in EagleFiler 1.2.7.
