I’m looking to make our software install DMG prettier and simple to build.
I’ve built a layout which works fine when I drop a local folder of files onto the DropDMG app, but when I download the existing DMG and drop either the DMG itself of the icon on the desktop representing the mounted DMG, the resulting DMG that is built doesn’t have the background image, or the icon placement.
Exiting DMG download: http://presstore_downloads.s3.amazonaws.com/awpst565.dmg
I’m also interested in whether I can make a single layout which would allow the filename of the pkg to change for different software versions, can I possibly use a placeholder for this I wonder?
Thanks in advance, happy to clarify if above not clear enough.
David
