Cannot create encrypted library
I tried to create a new encrypted library using the default settings (sparse image, 128-bit encryption) and get the following error:
EncryptedLibraryCreationError: 1: hdiutil: create failed - Inappropriate ioctl for device
This is on a OS X 10.10 Yosemite machine. Any suggestions?
This seems to be due to a bug in Yosemite. While I try to find a workaround, you may be able to create the encrypted disk image using Disk Utility’s File > New > Blank Disk Image command. Then tell EagleFiler to create a non-encrypted library on the mounted disk image.
EagleFiler 1.6.3 works around the OS bug that prevented this from working on Mac OS X 10.10.
