Capturing an RSS feed
I would like to capture an RSS feed from a Basecamp project as easily and as directly as possible. I saw in the support documentation that EagleFiler captures entries in NetNewsWire. I installed NetNewsWire, got the RSS feed going, but when I pressed the capture key I got a message that EagleFiler does not capture data from NetNewsWire.
Daniel.
The beta of NetNewsWire 4 does not really support AppleScript, and so it cannot work with EagleFiler’s capture key. NetNewsWire 3 is still available and is highly scriptable. It works with the capture key, and you could also use a script like this one to import from an RSS feed.
Thanks! That resolves this issue :slight_smile:
Daniel.
