Changeover from Entourage to Outlook 14.0.2
I just installed Office 11 and will be uninstalling Office 8.There are instructions in the manual for setting up Outlook 5, but nothing I could find about changing from Entourage. Naturally I want to keep the corpus, scripts, etc. so SS will go on working just as it did before. Thanks.
Tom Kirshbaum
You should follow the instructions for Outlook 2011.
Manual
Thanks. I guess I should upgrade my manual.
No need—the manual is built into SpamSieve’s Help menu.
