Since EagleFiler 1.9.2, EagleFiler has used Nitter to import Web pages from Twitter. Currently, the main Nitter instance is overloaded, causing pages to import with the error:
Instance has been rate limited. Use another instance or try again later.
You can use Terminal to tell EagleFiler to use a different Nitter instance, for example:
defaults write com.c-command.EagleFiler WebToolNitterDomain tweet.lambda.dance
or use:
defaults delete com.c-command.EagleFiler WebToolNitterDomain
to return to the default.
And here’s a script that will refetch the selected records (assumed to be tweets) using the current Nitter instance:
use AppleScript version "2.4"
use framework "Foundation"
use scripting additions
on run
tell application "EagleFiler"
set _selection to selected records of browser window 1
repeat with _record in _selection
my refetchWebPage(_record)
end repeat
end tell
end run
on refetchWebPage(_record)
set _url to _record's source URL
if _url is "" then return
try
set {_newRecord} to import URLs {my changeURLToTwitter(_url)}
on error
return -- Error fetching page; move on to the next one
end try
set _newRecord's container to _record's container
set note text of _newRecord to _record's note text -- does not preserve rich text
set _tags to _record's assigned tags
set assigned tags of _newRecord to _tags
set title of _newRecord to _record's title
-- Don't transfer since URL is different
-- set from name of _newRecord to _record's from name
set label index of _newRecord to _record's label index
set _record's container to trash of _record's library document
end tell
end refetchWebPage
on changeURLToTwitter(_url)
set _nsURL to current application's NSURL's URLWithString:_url
set _components to current application's NSURLComponents's componentsWithURL:_nsURL resolvingAgainstBaseURL:false
_components's setHost:"twitter.com"
_components's setQueryItems:(missing value)
return _components's |URL|'s absoluteString() as Unicode text
end changeURLToTwitter
