Color and Entourage 2008
I have an IMAC 10.5.2 and am using Entourage. Previously when Spam Sieve was not sure if a message was spam it would use the color blue. For some unknown reason the color blue is no longer appearing on those uncertain spam messages but instead the font is a bolder black
You can use the Edit > Categories > Edit Categories command to change the color that Entourage uses for the “Uncertain Junk” Category.
Thank you
Hi Michael,
Thank you for the very quick response. I can’t believe it was that simple to do. I was gonna try to edit the rules, thinking that was the way it needed to be handled
thank you again
