Command Line packaging
Im trying to understand how to automate the DMG process.
I have a configuration set up which I am happy with.
I can drag an app to DropDMG and it creates a DMG that I am happy with.
What I would like to do is to get DropDMG to bundle my app into a DMG after it has completed codesigning (which I am using App Wrapper 3 to achieve)
The help says ‘look in terminal and type man dropdmg’
I did that and I can see that it is possible to specify a file and a configuration, but I cannot work out the syntax. (the examples dont show this)
The man dropdmg window says ‘see the help for more information’ and the help says ‘see man dropdmg’ … impasse
Has anyone an example for using the commandline to
package the newly signed myapp.app into the yet-to-be-created ‘myapp.dmg’ using the existing configuration ‘banana’
dropdmg --config-name "banana" myapp.app
