Convert encrypted library to non-encrypted library?
If I start with an encrypted library, can I convert it to a standard library at some later point? I’d want to preserve everything as it is in the encrypted version.
I may have found the answer to my own question. If I mount the encrypted library file outside of EagleFiler, I can see all the files and folders that I’d expect to see in a non-encrypted library, so I assume I can drag and drop everything to a new folder and open it as normal. Would this work?
Yes, you would just close the encrypted library in EagleFiler, drag the library’s folder to a non-encrypted location, and open it from there.
