Using EF to convert a webarchive to rtfd will respect any modification made to the From field after importing the webarchive. But the title will be reset to some value that’s slightly different from the one assigned on import!
Thanks for the report. Right now I think it gets the title of the RTFD from the filename. In the next version I’ll fix it so that it preserves the title that you set for the Web archive.
This is fixed in EagleFiler 1.2.6.
