"Date Created" as view and sort option
Michael,
I keep looking for the option to modify the columns viewable in the main window. The equivalent of Command J - “Show View Options” - in the Finder. Want to add “Date Created” as a column and then use it as a sort option.
Am I missing something? Have looked everywhere. If it isn’t there, would it be possible to add it?
Regards,
Steve Jamieson
You can modify the columns by Control-clicking on them or by using the pop-up menu to the right of the column headers. “Date Created” is not currently available, but I’m adding it in the next version.
EagleFiler 1.3 adds a Date Created column.
