I know it’s possible to have EF open at log-in. I can’t see, however, a preference for the ‘default’ library to open.
I’d find it convenient to be able to set that, so EF is likely to be ready to go to work when I am.
Is this possible now?
You can set EagleFiler to remember which libraries were open when you quit it. Then, at login, you can have EagleFiler open and it will re-open them.
Another option would be to set a default library itself as a login item in System Preferences.
Yes… Sorry. Should have noticed that preference.
Thank you.
