Is there a way to delete empty folders in EagleFiler ?
I have this when I import a tree of folder containing docs that are already in the library but at another place
You can delete any folder by selecting it and pressing the Delete key. If you’re asking about finding the empty folders to delete, there is a script to do this or you could create a smart folder that looks for records with Kind folder and Size zero.
