Deleting an item from EagleFiler from a Tag view simply removes the tag, rather than deleting the item!
Perhaps a bug?
Thanks, Jeremy
This is a documented feature: it’s an easy way to remove a tag. iTunes playlists work the same way. You can press Option-Delete to instead move the record to the trash.
aha. That’ll teach me to not check the docs. Thanks for the clarification.
jb
