deleting file from source location when imported into EagleFiler
Is there way to have a file that’s being imported into EagleFiler automatically deleted from its source location?
Bill
You can import by using the Finder to move the file into EagleFiler’s “To Import” folder or the library’s Files folder.
Thanks Michael,
I set up aliases to each of my “To import” folders on my desktop - my primary source location for importing files into EagleFiler. I got accustomed to using the Fn F1 process to import files, but that always leaves me with the extra step of deleting the original files. Though adding aliases to my desktop adds a minor amount of clutter, moving files into EagleFiler seems more efficient than copying them there.
Bill
