Disabling gmail SPAM filter
Hi,
I’m using Mail to access my Gmail IMAP on Mac and if I follow SpamSieve’s instruction to disable SPAM filter, every time I send an email, one would appear in my Inbox.
Any work around?
Thanks in advance
I don’t think that will happen if you follow the latest instructions here because they make a filter that specifically excludes sent messages.
That’s strange cause that’s exactly how I’ve set up the filter.
Curious!
Updates: apparently by adding “is:spam” to “Includes the words” field, additional to the “label:sent” line, it does stop re sending to Inbox.
Thanks for the pointer Michael!
I was having the same problem with redundant sends to self, but this sorted it. Thank you Joe and Michael. But shouldn’t section 7.6.3 in the manual be updated?
I think this detail was added to the manual in September with SpamSieve 2.9.25.
