Does EagleFiler support .maf files? (Mozilla Archive Format)
Hi, I have several hundred webpages saved as .maf files. My question: Is this file format supported by EagleFiler? Can I import, index and tag such files?
Thanks.
Guenther Herbert
You can import and tag the files, and search them by filename. EagleFiler can do this for any type of file.
EagleFiler does not natively know how to read the .maf format, but it can display/index it if you have appropriate QuickLook/Spotlight plug-ins. (I’m not sure whether those exist for .maf; most well behaved Mac apps have built-in plug-ins for their own file formats.)
