DropDMG 3.6.7 does not work on Mac Sonoma 14.4.1
Quits immediately when started.
We’re not seeing that here, so I don’t think there’s a general problem between DropDMG and macOS 14.4.1. Please send in a crash log file and/or error log so that we can investigate what’s happening on your Mac.
Hi Michael
Sending a diagnostic report.
Version before 3.6.7 started to work and then crashed.
This version crashes as soon as a file is dropped on it.
Thanks for sending the report. I’m a bit confused because your first post said that it crashes immediately after starting. The second post says it doesn’t crash until after you drop a file onto it. No crash report file was attached nor mentioned in the error log . So it’s not clear to me whether it’s actually crashing (unexpectedly quitting) or simply reporting an error when you try to create a disk image?
The log shows that your recent disk image creations have failed because the code signing identity that you had told DropDMG to use is no longer in your Mac’s keychain.
Thanks for pointing me in the right direction.
Thde code signing id correct but obviously outdated.
Choosing the current version help fix the problem.
