In the manual you say:
SpamSieve - Account 1
Does that mean SpamSieve - me@myemail.com or
SpamSieve - me
SpamSieve - me
It’s ok I found from the script program that its the description field that you mean.
can you update the manual to make that clearer.
Just a suggestion.
Thanks
Yes, I will clarify that in the Setting Up an Apple Mail Drone section of the manual. In this case, the name of the rule after the “-” doesn’t matter; it’s just to help you keep track of what the rule does.
Ace!
Thanks.
