Hi,
Can I use Tresorit ( www.tresorit.com ) as my preferred solution to store my various EF libraries for use by iOS devices?
Thanks in advance.
Rolfe
Hi,
Thanks in advance.
Rolfe
I haven’t tried it, but it looks like others are using it with EagleFiler.
That’s great.
Thanks
I haven’t tried Tresorit either. Suggest to check out Nordlocker software: https://nordlocker.com/download/ . A tool that stores your files securely encrypted. Works fine on mac and is straightforward to use, but not sure about the mobile version
