DropDMG 3.1.3
Version 3.1.3 of DropDMG is now available. This is a free update for owners of DropDMG 3.0 that includes the following enhancements:
  • DropDMG is now code-signed using a Developer ID certificate for Gatekeeper.
  • Layouts and custom volume icons now work with hybrid (.iso) disk images.
  • DropDMG’s helper tools are now 64-bit like the rest of the application.
  • Improved the reporting of unexpected errors.
  • DropDMG now logs more information when a layout item is missing from the source folder.
  • Improved the What information should I include when I report a problem? section of the manual.
  • Fixed a bug where the Compact Image… command didn’t work on Mac OS X 10.7 when the computer was running on battery power.
  • Fixed a bug where Delete after converting
    didn’t work when converting to .iso format. - Fixed a bug where DropDMG would report an error when converting a .iso disk image to the same format.
  • DropDMG now requires Mac OS X 10.5.8 or later.
For information about previous releases of DropDMG, please see the version history.
