Version 3.2.3 of DropDMG is now available. This is a free update for owners of DropDMG 3.0 that includes the following enhancements:
- DropDMG now displays file sizes using the system standard style (requires Mac OS X 10.8 or later).
- The Burn OS X Install DVD
command has been renamed to Create OS X Install Disk. It now offers instructions for creating an installer disk (e.g. hard drive, USB stick, or SD card) for Mac OS X 10.9 Mavericks. - Fixed a bug where changes to the license agreement text weren’t saved if you created a new license or language using the action menu. - Fixed a bug where some disk image files were incorrectly owned by root if Always run with root access was checked.
- Fixed a bug where DropDMG would use a stale version number variable when you imaged an application, updated it (e.g. via the Mac App Store), and then imaged it again in the same DropDMG session.
- Automatic software updates no longer fail if Hazel is set to move files in the Downloads folder.
- Fixed a typo in the man page.
DropDMG 3.2.3 works with Mac OS X 10.5.8 through 10.9 Older versions are available for older operating systems. For information about previous releases of DropDMG, please see the version history.
