DropDMG 3.2.4
Version 3.2.4 of DropDMG is now available. This is a free update for owners of DropDMG 3.0 that includes the following enhancements:
  • DropDMG no longer posts errors to Notification Center. Instead, if DropDMG is not frontmost, it will bounce the Dock icon to alert you of an error.
  • Made some code signing changes for better compatibility with Mac OS X 10.9.
  • DropDMG is better at detecting errors when setting the background picture and arranging the icons.
  • Fixed a bug that could cause a crash when using DropDMG’s Automator action.
  • Fixed a bug that could cause an internal error when creating a hybrid disk image if the layouts preferences were open.
  • Fixed a bug where DropDMG could report an error when converting a disk image from .iso format to .dmg if the destination file already existed.
  • Updated the sample AppleScripts.
  • Updated the French localization.
DropDMG 3.2.4 works with Mac OS X 10.5.8 through 10.9. Older versions are available for older operating systems. For information about previous releases of DropDMG, please see the version history.
2014-01-28: DropDMG 3.2.4 has not been submitted to the Mac App Store due to a code signing bug in Mac OS X 10.9.x. However, if you purchased DropDMG from the Mac App Store, you can download and use the direct-sale version of DropDMG 3.2.4.
