Version 3.2.6 of DropDMG is now available. This is a free update for owners of DropDMG 3.0 that includes the following enhancements:
- In rare cases, Mac OS X 10.10 does not properly save the size of the mounted disk image window. DropDMG can now detect when this happens and report an error so that you do not inadvertently deploy a disk image that doesn’t look right. Usually, simply creating the disk image again will avoid the problem.
- The Layouts section of the manual now describes a problem with the rightmost 1 point of the background picture not being displayed in the Finder. For maximum compatibility with different OS versions, it is recommended that you design your background such that these pixels are not critical.
- Added the Mount Disk Image sample AppleScript.
- The About DropDMG window now uses the new system font on Mac OS X 10.10.
- The About DropDMG window now uses the system language names when crediting localizers, to reduce the number of strings that localizers need to keep up-to-date.
- Increased the font size in the Software Update… window on Mac OS X 10.10.
- Worked around an OS bug that prevented bookmark files from being resolved.
- Worked around a bug in Mac OS X 10.10 that prevented the Change Image Passphrase… command from working.
- Fixed a regression that prevented editing layouts on Mac OS X 10.6 through 10.8.
- Fixed a regression where the command-line tool did not accept none for the encryption.
- Fixed a bug where a change in system font meterics caused some text in the Preferences window to be truncated.
- Fixed a bug where DropDMG did not show Retina-resolution 515×512 icons in the Layouts window. (This did not affect the created disk images.)
- Updated the Italian localization.
DropDMG 3.2.6 works with Mac OS X 10.6.8 through 10.10. Older versions are available for older operating systems. For information about previous releases of DropDMG, please see the version history.
