Version 3.6.2 of DropDMG is now available.
This is a free update for owners of DropDMG 3.0 that includes the following enhancements:
- Worked around a bug in macOS 10.15 that prevented the Enter Passphrase… sheet from working from within the Get Image Info…, Mount Image…, and Verify Image… panels.
- DropDMG now maintains its own error log files, so you can still access information for troubleshooting when the macOS system log isn’t working properly.
- The software updater reports a more useful error message if you try to update DropDMG while running it from the disk image. This should prevent confusion where you continue running an old version despite telling it to update.
DropDMG 3.6.2 works with macOS 10.9 through 11.2.1. Older DropDMG versions are available for older versions of macOS. In-depth information about DropDMG is available in the manual.
