Here’s a new beta version of DropDMG. The changes are:
- Made various updates for macOS 15 and Xcode 16.
- Fixed a bug where DropDMG could incorrectly report a license agreement error when converting a disk image.
- Added
LayoutBackgroundFolderName to the esoteric preferences. This makes it possible to customize the name of the invisible folder where DropDMG stores the background picture.
If you have not installed a beta version of DropDMG before, first click here to enter the beta key. Thereafter, you can just launch DropDMG or choose Software Update from the DropDMG menu to auto-install the beta. DropDMG will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
