DropDMG 3.7.1b1 Public Beta
Here’s a new beta version of DropDMG. The changes are:
  • Fixed a bug where the Dock icon didn’t adapt to different themes on macOS Tahoe 26.
  • Improved the layout of the Software Update… sheet on macOS Tahoe 26.
  • Updated for Xcode 26.0.1.
  • Worked around a Help Viewer bug on macOS 14.
  • Added an Apple events usage description for the dropdmg command-line tool.
  • Fixed a regression where creating a disk image with a layout could affect the visibility of the path bar in subsequent non-DropDMG Finder windows.
  • Fixed the icon margins in the legacy ICNS file and documentation.
If you have not installed a beta version of DropDMG before, first click here to enter the beta key. Thereafter, you can just launch DropDMG or choose Software Update from the DropDMG menu to auto-install the beta. DropDMG will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
