DropDMG 3.7b3 Public Beta
Here’s a new beta version of DropDMG. The changes are:
  • When an app specifies both new (Tahoe) and old icons, DropDMG uses the newer one to generate the custom volume icon.
  • The status text in the main window now avoids the window corner radius on macOS 26.
  • Fixed the layout of the Set Passphrase… button on macOS 26.
  • Finalized the application icon.
  • Updated the screenshots in the manual.
  • Built with Xcode 26 RC.
If you have not installed a beta version of DropDMG before, first click here to enter the beta key. Thereafter, you can just launch DropDMG or choose Software Update from the DropDMG menu to auto-install the beta. DropDMG will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
Previously: Beta 1.
