EagleFiler 1.4.6
EagleFiler 1.4.6 is now available. This is a free update that includes the following enhancements:
  • The Drop Pad window now appears on all spaces.
  • When creating a Web archive, EagleFiler now uses the proper pagetitle for Web sites such as gmane.org that change the title usingJavaScript.
  • Added +$*/~()|%^& as characters allowed in tag names.
  • The search fields are now scrollable.
  • The ruler is now shown by default for editable rich text files.
  • Added keyboard shortcuts for showing, copying, and pasting the ruler.
  • Updated to version 1.1.7 of the SkimNotes framework.
  • Updated the instructions for changing an encrypted library’spassphrase to work around a bug in Disk Utility.
  • Improved the display of messages containing invalid Base64 content.
  • No longer adds a useless x-msg URL to the bottom of textimported from mail messages as RTFD.
  • Worked around a bug in the Safari 4 beta that could cause someimages not to be saved into Web archives.
  • Fixed a bug where the search wasn’t cleared when opening a folder ina new window with the ClearSearchWhenChangingSources esotericpreference enabled.
  • Fixed a bug where changing the plain text font didn’t change the fontof newly typed text.
  • Fixed a bug where the raw source for a message would sometimes showone extra character.
  • The crash reporter works better with pre-release versions of Mac OSX 10.6 (Snow Leopard).
  • The crash reporter now warns before sending a report without ane-mail address.
  • You can now press Enter to click the Send Report
    button in thecrash reporter.
  • Updated Korean localization.
