EagleFiler 1.5.10
Version 1.5.10 of EagleFiler is now available. This is a free update that includes the following enhancements:
  • The contextual menu Set Filename/From/Title
    commands are better at handling linebreaks. - It is now possible to move records to the trash by pressing Delete when multiple tags are selected in the source list.
  • The text fields in the smart folder editor make better use of the available window width.
  • Improved the Importing Mail From Outlook section of the manual.
  • Added the Importing Mail From MailMate section of the manual.
  • Improved the What information should I include when I report a problem? section of the manual.
  • Documented the TextInspectorBarStayOpen and UseOpenMetaRecentsForCompletion esoteric preferences.
  • Worked around a WebKit bug that could cause freezes when highlighting matching search terms.
  • Worked around a bug in Apple Mail that could lead to importing two copies of certain messages.
  • Worked around a problem where broken Mac OS X installations couldn’t report full error information.
  • Fixed a bug that could cause uncommitted changes in the tags bar to be lost.
  • Fixed a bug that could cause an error when the Quick Look window was open.
  • Fixed a bug where an incorrect error message could be displayed when capturing from Apple Mail.
  • Reduced the memory use of the Spotlight importer.
  • Improved the reporting of file permissions errors.
  • Worked around an OS bug that could cause a crash in Curio.
For information about previous releases of EagleFiler, please see the version history.
