Version 1.8.11 of EagleFiler is now available.
- The capture key now works in Brave Browser.
- There’s now an official PopClip extension for EagleFiler, which avoids the warning about the extension being unsigned.
- Scripts of the form
get first library record where its file is _fileare now optimized to quickly look up the record without having to check every record in the library. This can be useful if you have a Hazel script that receives a file and you want to do something with the corresponding record in EagleFiler. - Records now have a
last used dateAppleScript property, corresponding to the last time the file was opened in an app. - Records now have a
missingAppleScript property to detect whether the file has been moved or deleted. - Worked around a series of bugs in macOS 10.15 that could prevent images imported from Evernote from being sized properly.
- Worked around a change in macOS 10.15 that prevented certain OmniGraffle files from being displayed in the viewer.
- Improve importing of AudioNote files when AudioNote is not installed.
- Fixed a bug where importing an attached file from Evernote might not preserve its filename.
- Fixed a bug importing an Apple Mail mailbox that contained another mailbox with the same name.
- Worked around a macOS bug that could prevent launching EagleFiler after using AirPlay.
- Fixed a bug where e-mails containing HTML tags that were encoded with UTF-7 would not display properly.
- Fixed bug the viewer’s auto-save could cause pending tag changes to be saved prematurely, while the field was still in edit mode.
- The Activity window now uses the monospaced digits font to avoid jitter when indexing.
- The Slideshow button no longer causes an error to be logged.
- Modernized the localizations.
EagleFiler 1.8.11 works with macOS 10.9 through 10.15. Older versions are available for older operating systems. For information about previous releases of EagleFiler, please see the version history.
