Here’s a new beta version of EagleFiler. The changes are:
- Improved EagleFiler’s support for Importing From X/Twitter. When you press the capture key, tweets are now imported as HTML files rather than as plain text files.
- This works in Safari, Google Chrome, Brave Browser, and Microsoft Edge. Previously, only Safari was supported.
- This requires enabling JavaScript access in Web browsers.
- The filename and title are also improved.
- When capturing a Web page in Safari, EagleFiler has long been able to preserve the selected text in the record’s note. This can be useful for recording that a certain part of the page is important but also storing the full context in which it appears. This now works with Google Chrome, Brave Browser, and Microsoft Edge, too.
- Added
RevealRecordInParent to the esoteric preferences, which lets you control whether opening a record link shows the record in its containing folder rather than in the Records source.
- Updated the following sections of the manual:
- Made some improvements to EagleFiler’s detection of the current library when using the capture key.
- Updated to version 1.6.1 of the SkimNotes framework.
- Fixed importing of FastMail message files on macOS 15.
- Fixed a bug where indexing could be delayed if another library was busy verifying.
- Fixed a bug where the Activity window could look like it was indexing when indexing was disabled.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
Previously: Beta 1.
