Here’s a new beta version of EagleFiler. The changes are:
- Improved the formatting of community notes and quote tweets when importing from X/Twitter.
- Worked around a bug in macOS 15 where sometimes the system help viewer would not open the right help page. EagleFiler will instead open help files in the user’s Web browser.
- Fixed a bug where Merge Mailboxes/Message Files files might fail if the files were stored in iCloud Drive but not downloaded to the Mac.
- Fixed a bug where EagleFiler might improperly recognize certain folders as mailboxes when importing.
- EagleFiler no longer triggers the “find devices on local networks” prompt on macOS 15.
- Made some changes to track down an issue where files stored in OneDrive on macOS 15 might be incorrectly reported as missing.
- Removed support for Growl, as all supported macOS versions now have Notification Center built-in.
- Removed various unused code.
- Fixed the broken help button in the Settings window.
- The diagnostic report now includes information about the app’s logs, the crash logs folder, and components that could cause AppleScript errors.
- EagleFiler is now built with Xcode 16. We do not expect this to cause any visible changes, but it’s possible that some macOS frameworks will now behave differently when running EagleFiler on macOS 15.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
