Here’s a new beta version of EagleFiler. The changes are:
- Fixed a regression where dragging to the Dock icon didn’t work after minimizing a library.
- Fixed a bug where closing or minimizing a library window could unminimize another library.
- Updated the Edit Smart Folder… section of the manual.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
Previously: Beta 1.
