EagleFiler 1.9.19
EagleFiler has been updated to version 1.9.19. This is a free update. Normally, EagleFiler will automatically offer to update you to the new version. There are also instructions for updating on this page. EagleFiler 1.9.19 is compatible with macOS 10.13 (High Sierra) through macOS Tahoe 26 and is recommended for all customers using those versions of macOS. Older versions are also available for macOS 10.12 (Sierra) and earlier.
  • The capture key now works with DEVONthink 4.
  • The share extension can now import images with no associated file, e.g. from the Quick Look preview window after taking a screenshot.
  • Fixed a bug where tag searches with negative conditions sometimes didn’t find any matches when Match Partial Words was unchecked.
  • Worked around a Help Viewer bug on macOS 14.
  • Updated the documentation for macOS Tahoe 26.
