Here’s a new beta version of EagleFiler. The changes are:
- The share extension can now import images with no associated file, e.g. from the Quick Look preview window after taking a screenshot.
- The capture key now works with DEVONthink 4.
- Fixed a bug where tag searches with negative conditions sometimes didn’t find any matches when Match Partial Words was unchecked.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
