Here’s a new beta version of EagleFiler. The changes are:
- Added Import From Paperless script. This lets you import files from Mariner Software’s Paperless app (formerly called ReceiptWallet), which has been discontinued. The categories, collections, and other metadata will be translated to folders, tags, and notes in EagleFiler.
- You can now change the name of a tag via AppleScript.
- The
Keywordsheader of e-mail messages is now indexed for searching. - Deleting a tag now deletes its child tags instead of just changing their parents.
- Added the Differing Message Counts Importing From Apple Mail section of the manual.
- Updated the following sections of the manual:
- Updated to version 1.6.3 of the SkimNotes framework.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
Previously: Beta 1.
