EagleFiler 1.9.20b5 Public Beta
Here’s a new beta version of EagleFiler. The changes are:
  • When importing from Evernote, EagleFiler is better at handling attached files that have no filename extension and notes that contain only whitespace along with an attached file.
  • Made some changes to try to prevent a crash when displaying a table cell.
  • Fixed an internal error that could occur when checking whether a record needed to be indexed.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
Previously: Beta 4.
