Here’s a new beta version of EagleFiler. The changes are:
- Worked around a bug in macOS 27 that could cause a hang when dragging and dropping a message from Mail to EagleFiler.
- The capture key now works with the Thorium Web browser.
- Updated the following sections of the manual:
- Importing from Mariner Paperless is better at reporting progress and errors.
- Fixed a bug where replacing an old diagnostic report with a new one didn’t work.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
